It is currently Sat Aug 29, 2026 1:32 am
 Post subject: CPU sorting
PostPosted: Sat Jan 07, 2017 9:15 am
Thanks for the guidance and help!
 Post subject: Re: CPU sorting
PostPosted: Sat Jan 07, 2017 10:48 am
I will let lost sort for you but i can tell you that the i7 is worth a lot more than scrap if it works. you should take it out of the pile
PostPosted: Sat Jan 07, 2017 11:35 am
Thx! Typically my company does not toss good stuff, but I will see if I can find a way to test.
PostPosted: Sat Jan 07, 2017 1:14 pm
A)green fibre
B)green fibre
C)green fibre
D)green fibre with metal
E)pinless
F)pinless
G)pinless
H)pinless (or green fibre with metal if pins)
I)telco
PostPosted: Sat Jan 07, 2017 1:20 pm
The lattice (I) will also be worth a fair bit if it works. Probably more than the i7. It's a fully integrated SOC board. They run $75-150 on the high end and I can't find one under $35 at the moment.
