 Post subject: Weird boards
PostPosted: Tue May 13, 2014 9:35 am
I came across these boards. Don't remember what they came out of and have no clue what they would fall under.
13 is a triple layer board with 3 sets of seemingly gold pins. Bottom board has 1 set of pins with nothing else, middle has all the IC chips and 2 sets of pins, top has a couple of switches.
14 seems to be gold fingered with quite a bit of gold running trough it but it has a lot of garbage on it. (I clipped one and scratched the surface). Remove all the junk? Sell as is?
As always, Thanks!
 Post subject: Re: Weird boards
PostPosted: Tue May 13, 2014 7:52 pm
Looks like the board with all the IC chips has enough to warrant telecom grade. The board on the right in the second photo can go as a fingered card while the board on the left can go as mid-grade. I would remove the transformer first before selling the board.
PostPosted: Tue May 13, 2014 10:04 pm
You would be hard pressed for the one on the right to go as finger card. I would say peripheral.
PostPosted: Wed May 14, 2014 7:44 am
Actually the right card is the same card, just the underside. I think I will just clip the fingers and throw them in my mids. Thanks.
