It is currently Sat Aug 29, 2026 1:37 am
PostPosted: Mon Jan 23, 2017 10:51 pm
Please just put the card to the board type.
PostPosted: Mon Jan 23, 2017 11:18 pm
If I remove the removable IC chips and Eproms from the sockets of boards 6, 8, and 9 of spades will it down grade the boards and if so to what grade. Also if I just only take a couple IC/Eproms off of each of these boards would the grade stay the same?
PostPosted: Mon Jan 23, 2017 11:27 pm
9)peripheral remove Dallas box
8)telco remove Dallas boxes
6)peripheral
3)large socket remove pentium and send separate
Snip the battery loose CAREFULLY, below the isa ports.
2)large socket
PostPosted: Mon Jan 23, 2017 11:30 pm
9 remove ICs peripheral either way
8 no touch (leave ICs in)
6 no touch, your probably at midgrade without the 924s
PostPosted: Mon Jan 23, 2017 11:34 pm
Hey MLS; can you spy what's missing on the soc7 board?
Hint not the second socket 7
Bonus points if you can say why it's missing.
PostPosted: Tue Jan 24, 2017 7:55 pm
What is a Dallas box? Should it be removed to increase value?
PostPosted: Tue Jan 24, 2017 8:05 pm
The Dallas box is a battery and must be removed before sending in your order. They're socketed like standard ICs bit boardsort doesn't take them or anything containing them if attached on reception.
PostPosted: Wed Jan 25, 2017 9:52 am
Thank you Lostinlodos! Your generosity with your knowledge is a huge help and blessing! I will make sure to remove these.
PostPosted: Wed Jan 25, 2017 7:39 pm
By the way what's missing is the jumper pins for setting channels. This was an institution board. Settings are made on a prom and not the board for security.
Education, banking, or manufacturing were the common destinations.
Ctr shift F6 was the usual boot command to load the screen up.
