It is currently Sat Nov 07, 2026 7:01 pm
PostPosted: Thu Feb 09, 2017 10:57 pm
Hi, Just looking for help in identifying these boards, and what grade they fall under.
PostPosted: Fri Feb 10, 2017 4:37 am
Small socket. Everything is there
Peripheral if empty, gold finger card I'd have ICs
Low profile board. Small socket
Telco textbook
Telco don't remove anything
Telco barely but that nec is a nice full black fibre
High end high grade graphics card. Telco don't remove anything
VERY borderline scsi bus parallel or serial card. Telco as is, but only just barely
PostPosted: Fri Feb 10, 2017 4:42 am
I believe
If those dummy blanks are truly dummy blanks with no ICs on the flip side;
You'll probably get a better payout for the fingers. Those double row wide contact fingers weigh 1:3 vrs standard IS cards. So I'd cut one and do the math.
Fingerless the board would be midgrade.
PostPosted: Fri Feb 10, 2017 7:32 pm
Hi Lostinlodos,
The first picture you classed as small socket MB, can the gold fingers come off?
PostPosted: Fri Feb 10, 2017 9:08 pm
I'm not sure but I personally wouldn't. This is a very close call and removal may drop it to peripheral. But the difference in value is up to you.
