It is currently Sat Aug 29, 2026 1:36 am
PostPosted: Sun Jan 29, 2017 4:12 pm
What are these from number 1 to 8?? I have the front and back of each one
PostPosted: Sun Jan 29, 2017 10:46 pm
With the one exception these all appear to be BGA CPUs, no pins, so I'm going based on that.
1)green fibre with metal
2)if it's gold it's ibm/via gold cap. If it's the flash then green fibre with metal
3)green fibre with metal
4)green fibre with metal
5)green fibre with metal
6)if gold ibm/via gold cap. If aluminium black fibre
7)green fibre with metal
8)green fibre with metal
Not all BGA flats go like this though
PostPosted: Mon Feb 13, 2017 3:30 am
What about number 4?? No ibm/via gold cap like number 2? And if so, could all of the chips be combined together if they fall under the same catagorey??
PostPosted: Mon Feb 13, 2017 4:08 am
I'm not sure from the photo if 2 is a gold cap or aluminium and it's the flash
4 is definitely green fibre with metal
PostPosted: Mon Feb 13, 2017 5:40 am
Heres another pic
PostPosted: Mon Feb 13, 2017 5:42 am
So if the other chips all fall under the same type can they be mixed together or do they still need to be separated, even if they will be as the same pay per lbs?
PostPosted: Mon Feb 13, 2017 12:58 pm
It looks to be a gold cap and thus will have it's own payout. My best guess would be IBM/via gold cap. It has no pins.
You can mix by classification.
With metal all together
No metal together etc
