It is currently Sat Aug 29, 2026 4:33 am
PostPosted: Tue Feb 21, 2017 10:25 pm
I think some of these are border line telco and some others I'm just not sure of.
Thanks
PostPosted: Wed Feb 22, 2017 2:49 am
Never mind see below I got it
PostPosted: Wed Feb 22, 2017 2:57 am
In order
Peripheral
Peripheral
Peripheral
Peripheral
Peripheral
Peripheral
Both peripheral
Telco
Peripheral
Telco
Peripheral
Small one is peripheral don't remove the IC
Two large are telco
PostPosted: Wed Feb 22, 2017 9:15 am
IMG_0664: that riser board is removable. If I pull it will that upgrade it to Telco?
IMG_0656: should I pull the NEC card?
IMG_0652: Just to clarify the green board is Telco?
On the most of those peripheral boards the bigger IC's are removable....can I pull those and still get peripheral or will it down grade them to mid-grade?
PostPosted: Wed Feb 22, 2017 1:49 pm
64 yes no
Pull the board they're both peripheral. And you probably should if it comes out. Pull the socketed ICs
56 absolutely
52; I'm debating on this one. Ultimately what it goes as is going to be at the will of the person who verifies your box. There's a lot of real inside recycling experience that has me leaning telco like the pressed fibre board and lots of gold pins, the volume of copper, but is it enough?
I'd personally toss it on telco, but it's truely a fence sitter.
PostPosted: Wed Feb 22, 2017 3:53 pm
What will that NEC card go as? Will it go as is or do I need to pull the board out of the plastic housing?
PostPosted: Wed Feb 22, 2017 4:47 pm
The board itself can go anywhere from peripheral to gold cap board (and rarely even higher) once out of it's shell just be careful not to break the connector off.
