It is currently Sat Nov 07, 2026 7:19 pm
 Post subject: Sas drive tear down
PostPosted: Tue Mar 21, 2017 3:17 pm
Hey guys bit of a newb to drive tear downs but I've done a few older SCSI drives and ide/sata drives. My first time opening a 2.5 sas drive and I found this little board attached to ribbon on the actuator arm.
What would be the best way to handle the small board. Haven't seen any of these on eBay or what term I should even search for. Looks like a decent amount of gold plate.
Thanks
 Post subject: Re: Sas drive tear down
PostPosted: Tue Mar 21, 2017 4:56 pm
There's actually not all that much there. It's thinner gold than in gold laminate.
If it has an IC chip on it I toss them in peripheral.
If not I'll peel it off the base; you probably put it in wire once you remove the aluminium.
