It is currently Sat Jul 04, 2026 3:53 pm
Post new topic Reply to topic  [ 126 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
 Post subject: Need help with board ID
PostPosted: Wed Mar 22, 2017 9:38 pm
I recently bought a huge 7 pallet lot at a local auction of city traffic light controllers and cameras. Roughly 100 control boxes and 35 pelco cameras.
These are some of the boards. Not sure if they are going as telecom, gold finger boards, and or what? Board 1 is a finger card and a female gold pined card, board 2 has alot of IC chips and some gold/yellow colored caps ( will remove all large caps on these boards), and board set 3 is stacked, one has gold fingers, the other is full of IC chips. I will remove the aluminum brackets and any screws/stand-offs. Theres roughly 2000lbs of aluminum total here.
PostPosted: Wed Mar 22, 2017 11:12 pm
Big pile of mixed electronics
Top peripheral bottom probably gfc but need to see rest
Borderline. I lean peripheral see if MLS has thought
Both peripheral. If Remove fingers you'd get low grade
Remove all brackets from this stuff to get mentioned grades
PostPosted: Thu Mar 23, 2017 7:57 pm
This bottom one (board 4) is the board pictured above as gold finger, there is a small "push button" tan board next to it. Then 2 more, board 5 and 6.
PostPosted: Thu Mar 23, 2017 10:24 pm
I would agree with lodos's assessment... pull the two cards apart and get Goldfinger card for the one half.
PostPosted: Fri Mar 24, 2017 2:40 am
The tan one is midgrade
5 is telco but if you remove anything it will be peripheral
6, first board, is peripheral
PostPosted: Fri Mar 24, 2017 7:32 am
Sounds good. That board 5 did have a large transformer on it (a few pounds) that I had to pull off. There will be a lot of boards like that one in this lot for sure. As I get more pulled, ill post more pics. I appreciate your help.
PostPosted: Fri Mar 24, 2017 10:15 am
Looks like you pulled a big capacitor from 5 two, which is a good idea. You'd have had peripheral if they were on there
PostPosted: Fri Mar 24, 2017 11:20 am
yes, all large cylinder caps I pull off. That board didn't have a transformer now that I remember, that was another one I have yet to post. There should be a lot of telecom boards in this pile of equipment considering what it did for traffic signaling.
PostPosted: Fri Mar 24, 2017 6:01 pm
another one, same board top and bottom.
PostPosted: Fri Mar 24, 2017 7:46 pm
Peripheral
It's incomplete flashing and not a sandwich board
