It is currently Sat Aug 29, 2026 4:34 am
 Post subject: Anything special?
PostPosted: Sat Apr 15, 2017 9:14 pm
Is there anything special or anything worth taking and selling apart ?
 Post subject: Re: Anything special?
PostPosted: Sat Apr 15, 2017 10:00 pm
Assuming it all works?
Right off that's a nice soundblaster and fan controller.
That I/o card has FireWire so not much but can definitely sell easily.
PostPosted: Sat Apr 15, 2017 11:32 pm
I don't have a monitor to check if it works but my neighborhood is having a cleaning we you can dumb outt anything and garbage will take it and find this baby from some guys garage
PostPosted: Sat Apr 15, 2017 11:33 pm
Would you recommend cleaning then and trying to sell it after clearing all the dust it accumulated lol
PostPosted: Sat Apr 15, 2017 11:34 pm
And what about the wiring anything special in them or just for show
PostPosted: Sun Apr 16, 2017 12:19 am
It's a fairly outdated gaming system. The wires are for show
Not knowing the condition; stuff like this ends up trashed for one of two reasons more than anything else.
Kid went to college and parents are clueless
Bad fan burned up the cpu.
The first thin you'd want to do is SLOWLY pull out all the wires one connection at a time and look for any signs of burnt board.
That would rule out any kind major surge. From there remove the power supply to get some room to work and pop that cpu cooler off. Again looking for anything out of the ordinary.
Still looking good?
Toss the sound card and front dock
And that I/o card
On ebay AS IS Untested
The SB set should pull around $25-$50 having the whole kit. (Don't loose the crossover wires between the dock and board).
IO with FireWire should be $5-$10 unknown
I wouldn't mess with the rest of it beyond scrap not knowing conditions.
PostPosted: Mon Apr 17, 2017 1:49 pm
Thanks for the advice will try it out this weekend and what is front dock?
PostPosted: Mon Apr 17, 2017 4:41 pm
Here you go
PostPosted: Tue Apr 18, 2017 2:04 pm
That design from soundblaster was, and is, popular for full size cases.
The front dock is actually quite short compared to some competitors and will even fit in front of some popular fan bay units with some fancy wiring applied. Helping it to hold its value as it ages. And the docs and cards are SOMEWHAT interchangeable with each other allowing X2 and xfi etc to be paired up for differently uses.
If you knew for sure it worked you cpu get a fair bit more, but as is for something you pulled from a curb it's a great score regardless.
I used an X2 dock with my xFi card for a long time since the dock gave me rca I/o and the card supported 14.3.
