 Post subject: p2 cpu
PostPosted: Thu May 29, 2014 3:37 pm
This is cpu from a p2 laptop. No metal so green fiber no metal?
 Post subject: Re: p2 cpu
PostPosted: Fri May 30, 2014 10:47 am
It will go with green fiber with metal. The capacitors on the board downgrade it. Removing them may harm the value of the board even more.
PostPosted: Fri Jun 06, 2014 1:08 pm
That will in fact go into the Green Fiber WITH Metal grade.
When you do the calculations it will pay likely more than a single green fiber no metal chip will, as those GFNM chips are extremely light weight, where this P2 card is heavier, which will in turn pay out better, even at the lower rate than a single GFNM will.
