It is currently Thu Aug 27, 2026 6:17 am
 Post subject: No Pin Processors?
PostPosted: Sat Jun 07, 2014 8:45 am
If I remove the gold pins from a Green Fiber No Metal CPU or a Green Fiber with Metal CPU, do they go under the catagory of a "No Pin Processor"?
 Post subject: Re: No Pin Processors?
PostPosted: Mon Jun 09, 2014 11:29 am
I would say yes, but you may end up losing money in the process because you need to ask yourself if the value of the pins when removed will be worth more than the chip they came from.
