It is currently Sat Aug 29, 2026 4:44 am
 Post subject: Mono or perif?
PostPosted: Fri Jun 02, 2017 10:07 am
Happy Friday!
Not sure where this falls, have seen router boards go mobo in the past, I am just not knowledgeable enough to know what lifts it to that level.
Just a small IC and a bunch of SMDs on the back, not worth the extra pic.
 Post subject: Re: Mono or perif?
PostPosted: Fri Jun 02, 2017 12:16 pm
This board is peripheral grade I believe. Hopefully Lost will concur.
PostPosted: Fri Jun 02, 2017 1:02 pm
Router board range from peripheral 90% of the time to; mobo (server boards that are separate rack units)and telco (high end of the previous)
This is peripheral
PostPosted: Sat Jun 03, 2017 7:53 am
Telecom. Normally these do fall under peripheral, but those type of "gold corner" computer chips are valuable.
PostPosted: Sat Jun 03, 2017 7:57 am
Oops.... Sorry, the way I viewed it the first time, I thought all the small ones were gold corner chips... When I went back and zoomed in on the higher resolution pic, it looks like just the two in the middle that are gold corner, so it should fall into peripheral... My bad.
PostPosted: Sat Jun 03, 2017 12:58 pm
No worries, great info, thanks all!
