It is currently Thu Oct 29, 2026 1:49 pm
PostPosted: Tue Jun 06, 2017 11:26 pm
Does Boardsort purchase broken low and mid grade boards. say for example a low grade board from a power supply that has had the copper bearing motors or AC motors and aluminum heat sinks removed?
PostPosted: Wed Jun 07, 2017 11:00 am
i believe so, but the cost of shipping may be prohibitive on your end. you would have to do some calculating before you send it off and figure out if its worth it.
and depending on how much you strip off, you might even get a down grade, so if you send them a large amount you might want to check with them and send some pictures to get a confirmation.
PostPosted: Wed Jun 07, 2017 1:25 pm
They do. Though if you take the cbm and aluminium off midgrade you'll get low grade for them.
Most power supply boards are midgrade due to the cbm involved, but as soon as you start pulling things you'll move to low grade very quickly.
