It is currently Fri Nov 06, 2026 5:41 am
 Post subject: what would this be
PostPosted: Thu Jul 20, 2017 9:01 am
came out of an old power supply. I cut one of the wires and it looks like gold wires. If I cut them off what would it be?
 Post subject: Re: what would this be
PostPosted: Thu Jul 20, 2017 6:22 pm
As is the board would be peripheral. The 'nubs' are nickel, brass caps, brass mounts, the pins/wires are a low level gold alloy. I got $37 per ounce from my very trusted refinery for them a few month ago. It is clean-ish gold, but of very low content. Enough with everything to bump to peripheral rate but I wouldn't cut it off. Without the gold you'd probably fall to midgrade and loose money on the "pins".
PostPosted: Fri Jul 21, 2017 11:41 am
thank you
