It is currently Thu Nov 05, 2026 9:03 am
PostPosted: Fri Aug 04, 2017 2:14 am
I am new to this and I need help...
PostPosted: Fri Aug 04, 2017 2:53 am
13)this first is a fluke. This one is peripheral
Normally boards like this will be midgrade
12)peripheral if they have The gold tension port like this one or the DLP/DSP on it. Midgrade when they don't
11)peripheral
10)peripheral
09)this should clear telco
08)telco
07)peripheral
Another fluke if the OKI m7 cpu is socketed you can pull it and get AMD ceramic rate for it. The board would then go midgrade. Those m7 pins are a low grade bell silver, not nickel tin. If it is in a dip socket Do NOT force it out though those are notoriously not properly fitted and , literally, ripping the pins off is every classic tech workers worst nightmare. Without the pins you'd have a standard ic and the board by default would again be midgrade. So be very gentle if it's socketed.
06)telco here. You've got two soldered 60c62 ICs for the jump.
05)Totally missed it. Gold cap chip board
04)I'll say telco here on the lowest end of the class. Nice AMI and four silver cap rhodium fuses
03)telco
02)gold finger with the shield off, peripheral with the shield on
01)midgrade
PostPosted: Fri Aug 04, 2017 12:25 pm
#5 will go as gold capped chip board.
PostPosted: Fri Aug 04, 2017 9:21 pm
YES I totally missed them.
PostPosted: Wed Aug 09, 2017 5:41 pm
They gave me telecom for those boards..
.dang it...lol
PostPosted: Wed Aug 09, 2017 10:04 pm
Probably the extensive weight offset. Sorry.
