It is currently Sat Aug 29, 2026 8:58 am
 Post subject: I D please
PostPosted: Mon Sep 04, 2017 4:30 am
These are small, the company has 110lbs of them. Thank's
 Post subject: Re: I D please
PostPosted: Mon Sep 04, 2017 1:19 pm
Look to clear telco. Gold finger, sandwich board, dense population.
Telco
PostPosted: Mon Sep 04, 2017 2:13 pm
Thank's los. Question some of these have have the small soldered strip on the back, as seen in pic, most don't. Do this need to be removed to clear telco. I was hoping telco gives a little leverage to bid on these. Most of the boards we get are mixed and sold for .10cent a lb.
PostPosted: Mon Sep 04, 2017 2:17 pm
I personally wouldn't worry about it. The solder is most likely nickel tin, valuable enough to not hurt the grade.
PostPosted: Mon Sep 04, 2017 4:23 pm
Thank's los.
PostPosted: Mon Sep 04, 2017 5:34 pm
If you are going to bid on these, I would get a quote from Chris first... I think you are looking at gold finger card, but I have seen some of the air cards that look similar go for less... also with 110 lbs, they may bump the price up a bit just because of volume.
I don't think telecom is out of the realm of possibility, but better safe then sorry (or out money).
PostPosted: Wed Sep 06, 2017 4:47 am
Thank's mls, sent Chris an email.
PostPosted: Fri Sep 08, 2017 4:38 am
Just an update, Chris replyed back, telco. I'm gonna offer a fair price because if they go in the mixed board box it's only .45cents a lb. Thank's
PostPosted: Fri Sep 08, 2017 11:24 am
Awesome!! Glad to hear you got a confirmation, it helps to take the uncertainty out of things :)
