It is currently Sat Aug 29, 2026 6:06 am
 Post subject: Grading fingerboards
PostPosted: Thu Sep 14, 2017 1:41 am
Quick question are finger boards graded by color ? I am assuming I need to remove fans and heat sinks ? What about the D-link card ?
Thanks
 Post subject: Re: Grading fingerboards
PostPosted: Thu Sep 14, 2017 2:45 am
Fans always need to be removed.
That heat sink falls into large/oversized and should be removed ved as well
The dlink card if it's screwed in or glued on should be removed. They may downgrade that otherwise. If it's soldered or riveted they generally let it pass since there's not much you can do.
PostPosted: Thu Sep 14, 2017 7:32 pm
What about the color?
PostPosted: Thu Sep 14, 2017 8:16 pm
Colour only matters on motherboards.
PostPosted: Thu Sep 14, 2017 8:22 pm
thanks you guys are great
