It is currently Fri Oct 30, 2026 5:43 pm
PostPosted: Fri Oct 06, 2017 7:28 pm
These are some of the better boards out of a heating system and I'm kinda new with scrapping boards can I get a little help. I had two of each so each one is front and back. Thanks
PostPosted: Fri Oct 06, 2017 9:18 pm
I only ask because the gold plating and printing on the boards. I know they aren't extremely high grade but what would they be sort as
PostPosted: Sat Oct 07, 2017 12:03 pm
Everything posted is peripheral. Including the brown back: for the same reasons some remote controller boards get peripheral: the gold flashing and bump IC.
-0519, those are tin plated nickel fins. Which may or may not have have a brass core. Gouge or cut one. If it’s completely nickel and your local yard buys it break them off: you’re better off selling the nickel, it’s worth more than the board class (the board would then be midgrade). . If it’s a brass base underneath leave them on and take the peripheral rate.
PostPosted: Sat Oct 07, 2017 1:10 pm
Thanks!
