PostPosted: Sun Oct 15, 2017 9:42 pm
File comment: and this one
File comment: All the Backs are clear like this one
I have
PostPosted: Sun Oct 15, 2017 11:41 pm
1)peripheral
2)back
3)removal the cpu for telco board and and a IBM/VIA Gold Cap CPU (otherwise it's gold cap chip board).
4)again remove the NEC and see #3
5)telco
6)telco
7)see 3
8)Telco
PostPosted: Mon Oct 16, 2017 9:46 pm
Those boards look identical to a batch that I just sent in lol... See this: viewtopic.php?f=4&t=4852
Those NECs are soldered in place unfortunately... would that upgrade the board to gold cap chip board? I sent mine in for telecom...
PostPosted: Mon Oct 16, 2017 9:52 pm
lostinlodos wrote:
1)peripheral
2)back
3)removal the cpu for telco board and gold cap ceramic
5)telco
6)telco
7)see 3
8)see 3
Thanks
PostPosted: Tue Oct 17, 2017 1:07 am
I’m not sure at this point if they qualify for gold cap. I’ll ask Chris. They did, then they didn’t, then they did again. Lol
I haven’t sent any in quite some time so I’ll ask and get back to you.
Not sold they’re soldered. Most of the ones I’ve seen have had very stiff sockets (HIFR). You need to get your spudger in just the right place and angle (or use a thin flat head screwdriver or a scraper since you’re scrapping it).
Not saying your wrong, just that all the ones I’ve seen so far we’re just super tight, not soldered. And the ones pictured look like they’re in HIFR stub pin sockets. I can see a black plastic outline between the cpu and the board.
PostPosted: Tue Oct 17, 2017 2:11 pm
Code:
Just shot Chris a letter so as soon as I know I’ll post the answer. That way I can be sure.
Quote:
The chip would be priced as a Cyrix Gold Cap and if it was fixed to a
board the board would be a Gold Cap Chip board.
PostPosted: Mon Oct 23, 2017 12:58 pm
lostinlodos wrote:
Code:
So the Boards with the Soldered NEC Processor with the Gold Lined top may be Gold Capped Boards? These NEC Procs are Soldered. I will heat and remove unless they raise the board price. I live in Florida so I have to watch my shipping costs. And hey thank you for the fast responses.
PostPosted: Mon Oct 23, 2017 1:00 pm
Oh and these boards are very old and ran a Floroscope machine so the are heavy with the good stuff.
PostPosted: Mon Oct 23, 2017 2:33 pm
Yes the boards with the NEC them would be gold cap chip board. If it’s soldered they would be stub pins, leave them alone. Stub pin chips get downgraded depending on pin length and pitch regardless of cap and it’s just not worth it. Ever. I’ve tried for years and never got ahead removing one.
DEC and IBM are the only two companies I’ve ever seen with soldered pga chips that were full pin. Both for mainframe/mini boards.
PostPosted: Mon Oct 23, 2017 2:40 pm
Thanks and Ill add some side shots for reference to help others hopefully
