It is currently Sun Jul 05, 2026 9:46 am
 Post subject: ID help
PostPosted: Wed Nov 08, 2017 1:55 pm
Have an assortment of boards needing help identifying. Any help as always is greatly appreciated! You guys take care of us! Thank you!
 Post subject: Re: ID help
PostPosted: Wed Nov 08, 2017 4:37 pm
1)cd/dvd boards
2)1 cd/dvd board, two fingered cards are peripheral
3)looks like hard drive boards
4)peripheral
5)telco
6)top telco bottom peripheral
7)cd/dvd boards
PostPosted: Wed Nov 08, 2017 6:29 pm
in the second to last image where you have a telecom and a peripheral boards, the telecom board seems to have a small ceramic cpu. I think that cpu can go for Foreign Motorola Cpu grade. There is also a white IC chips kind of blurry but if the top is gold plated you may have here a 8086 Gold Cap with Gold Legs IC. If it is just a white color IC chip then just leave on the board.
Cheers
PostPosted: Thu Nov 09, 2017 10:15 am
There’s also a lithium battery on that telco board that needs to be removed before sending it in
Unless it has a gold cap on the pin side I believe that ceramic is a stub pin pentium Mac ceramic (capless) or BGA pinless and probably soldered to begin with
PostPosted: Thu Nov 09, 2017 7:07 pm
1St Picture . Left top and bottom are actually hard drive boards. Second picture the board without fingers also came from a hard drive. So does Boardsort grade some certain hard drive boards as peripheral? They look like the newer hd boards so I was wondering.
PostPosted: Thu Nov 09, 2017 11:50 pm
Your right on the top two or left two depending on how it loads, what o was seeing as audio pins are actually the jumper pins. Good eye.
The bare square ones won’t get hard drive class because of the design.
The sata board in that second pic looks like the bottom of a Mobile disc drive.
If it’s from a hard drive feel free to toss it in with hard drive boards.
I’m eyeballing from photos so I’m guessing on some things. When we get into Mobile and half height stuff I’m shot on the dark 50/50 etc on hdd vs dvd.
The ones with the fingers though look like tape or zip boards.
