It is currently Tue Jul 07, 2026 12:54 am
 Post subject: Help
PostPosted: Mon Nov 13, 2017 11:45 pm
I think I know what some are but want to double check
 Post subject: Re: Help
PostPosted: Tue Nov 14, 2017 10:40 am
13)peripheral
12)green brown fibre
11)peripheral
10)peripheral
09)peripheral
08)midgrade
07)peripheral
06)peripheral
05)peripheral
04)gold finger ram
03)cell phone board (remove shields)
02)peripheral
01)large socket (laptop) if you can remove the bracket on the bottom, small socket if you can’t.
PostPosted: Tue Nov 14, 2017 11:17 am
#13 the ic looking thing has gold legs, I think it's out of a mini mouse. Is it worth removing? And #6 came out of a cd/DVD rom from a laptop but it doesn't make cd/DVD? And #10 has gold fingers but only peripheral grade? I'm sure you're right but just wondering why these things are what they are
PostPosted: Wed Nov 15, 2017 12:10 am
10!is a fairly low end riser board. The finger keeps it at peripheral.
Optical/laser mice diodes are hit or miss but generally will get peripheral on their own so no sense in removing it.
With laptop drives , any type, if I can’t spot it as something better on first glance it will generally fall in to peripheral on reception at boardsort. Reduced size controllers usually hit either peripheral or telco. There’s fudge room but I’m not seeing it here.
PostPosted: Wed Nov 15, 2017 12:15 am
Mouse optics have been discussed and debated to death. Resurrected multiple times and beaten to death again. Bottom line is about 1 in 10 will get a second glance before being tossed into peripheral by the site workers. Excluding some rare ones these days with 8 or 12 legs that clear IC class the pins alone aren’t enough. Peripheral for same reason a basically blank 3.5 inch controller gets peripheral on the pins alone.
None of us can tell you within 100% certainty that they will go one way or another from a photo.
On the extreme end that goes for all boards. Ultimately it’s up to boardsort, and even there it’s not set in stone till someone is holding it or Chris says he’ll promise it.
