It is currently Mon Oct 26, 2026 11:00 pm
 Post subject: I assume telco
PostPosted: Fri Jan 12, 2018 6:57 pm
Will they still be with the fingers trimmed
All pictures are from and back
And do I need to trim anything else from the boards?
 Post subject: Re: I assume telco
PostPosted: Fri Jan 12, 2018 8:48 pm
The first board you show could fetch telecom, but the second one has more blank spaces where ICs would normally be at, so I'm inclined to leave it as a gold fingered card. Lostinlodos usually chimes in as well.
PostPosted: Fri Jan 12, 2018 9:20 pm
The first two will be telco if you leave the fingers on. Don’t remove them. The last one looks too empty to make telco so I’m with K on goldfinger card
