 Post subject: Well glued heat sink
PostPosted: Sun Jan 28, 2018 11:49 pm
Does this heat sink need to come off? If so how can I get it off? I tried to pull it with a pair of needle nose pliers and it acts like it's going to pull the chip off the board.
 Post subject: Re: Well glued heat sink
PostPosted: Mon Jan 29, 2018 2:59 am
needle nose probably dont give you sufficient grip/leverage. Try a pair of channel locks. If you can't just rock back and pop it off with those sometimes you can try rotating it to get it to pop. Sometimes I'll just slip a flathead screwdriver under there and turn it, too
PostPosted: Mon Jan 29, 2018 3:56 am
That’s small enough in ratio to the board to ignore at this point and to just move on.
PostPosted: Mon Jan 29, 2018 8:31 am
Will do....thanks for all your help Lost :)
