It is currently Mon Sep 28, 2026 7:07 pm
 Post subject: SO. MANY. THINGS.
PostPosted: Tue Mar 06, 2018 12:21 am
@Lost - I apologize for the sheer volume here. These are either older than what I normally deal with or from applications I'm not used to (or have some heavy items throwing me) and so I'm not sure how to categorize.
I figure this might take you a bit to work through...appreciate your help.
 Post subject: Re: SO. MANY. THINGS.
PostPosted: Tue Mar 06, 2018 4:01 am
Ohh, old stuff. =)
I’ll get started here but some of these I need to go back over what I’ve sent or may need a second opinion, or e en Chris on.
So here we go:
29)telco. Snap the vertical board off. Remove wires and battery
28)remove all plastic. Separate the cards. Repost front and back for accurate ID
27)heavy. Lots of aluminium. Old seagates May have a cobalt magnet on the bottom. Most steel yards buy them even if they don’t take neodymium ones. Have a blue or green tint to them.
26)peripheral
25)readout board. More value than it looks. Peripheral
24)cut the wire. Little board mid grade big one peripheral
23)peripheral
22)yep mid grade
21)peripheral
20)peripheral. The SL isn’t the full CPU.
19)it’s a SATA board. First thought is cd/dvd class. Doesn’t look like a hard disk controller
18)probably mid grade.
17)gold finger card, remove the attached small board
16)was telco if full. Peripheral as is. Peripheral without the big ICs so remove them for IC rate. Leave the little ones alone
15)mid grade
14)remove that aluminium heat sink, keep it separate in your shipment. It may get an upgrade to mid grade depending on where the market is on reception. Had similar go both low and mid
13)mid grade
12)backplane
11)telco
10)mid grade
09)peripheral
08)mid grade
07)mid grade. Yank the wires off
06)cut the finger. Toss in telco. Board is low grade then. Don’t heat it. The traces are nickel lead.
05)peripheral
04)telco (barely)
03)it’s nickel lead, and it’s mid grade
02)oh so barely peripheral
01)Bare one is midgrade, I’d cut the connectors off (gold pin connector) and dump the resulting low grade board
Rest are peripheral
PostPosted: Tue Mar 06, 2018 4:29 am
Like Zeppelin implied NOT all that glitters is gold. And as such not all that shines is silver. Keep those gloves on and wash up well when you’re done, with those lead ones.
PostPosted: Wed Mar 07, 2018 4:02 pm
#28 separated
PostPosted: Wed Mar 07, 2018 4:15 pm
Smaller one is mid grade
Larger one is telco.
