It is currently Mon Sep 28, 2026 5:05 am
 Post subject: Couple more to ID
PostPosted: Thu Mar 15, 2018 6:04 pm
Got a few different boards to ID. Are floppy drive boards worth messing with. It is a brown board on one side but looks like gold pins on it number 4 in pic
 Post subject: Re: Couple more to ID
PostPosted: Fri Mar 16, 2018 11:45 am
1. Telco. This board appears to have come from an SSD; if you had the equipment to test an SSD and the test passed, I would advise against scrapping it.
2. Peripheral. This board came from a PCMCIA Wi-Fi card.
3. This one came from a desktop memory card reader. The bigger board is peripheral while the small board is midgrade. Both are connected to each other with a wire, which you should cut and would go as mixed wire.
4. Peripheral.
PostPosted: Fri Mar 16, 2018 1:50 pm
Always appreciated guys. Thanks again
PostPosted: Fri Mar 16, 2018 8:33 pm
5 reinforced treated paper. 2 cents per lb per ton
6 barcode. No extra value on its own.
Floppy drive boards with pins or a gold finger go as peripheral.
PostPosted: Fri Mar 16, 2018 8:47 pm
Thanks lost.
I knew number five and six we're going to be tough to identify but man Nothing Gets By you LOL
PostPosted: Fri Mar 16, 2018 11:09 pm
We’ve got to have fun on occasion too.
