It is currently Mon Sep 28, 2026 7:19 am
 Post subject: Couple of more
PostPosted: Sat Mar 17, 2018 1:44 pm
The black one I'm not sure if it peripheral or midgrade, the pins are gold.
The green one I'm sure it's nothing more than peripheral, but can I pull the gold pins for "clean gold pins" with out down grading the board?
Pictures are front and back.
 Post subject: Re: Couple of more
PostPosted: Sat Mar 17, 2018 3:10 pm
They’re both peripheral. I wouldn’t remove anything. I send a bunch of these now and again. Old controller units. They just barely make peripheral.
Code:
NOT what I was expecting
PostPosted: Sat Mar 17, 2018 6:02 pm
id say those are on the higher end for a remote board thats something you dont see everyday gold plated contacts on a cover for exteranl devicies
gen select interesting .
Code:
gns2001
PostPosted: Sat Mar 17, 2018 6:34 pm
Those come out of a dash mounted police radar controller.
PostPosted: Sat Mar 17, 2018 6:55 pm
Code:
gns2001
Kool! From the size I just figured it was a Betamax or reel controller. Didn’t make sense on the distance marking though,
Now it all makes sense
That also says, though my initial thought on the black boards may be off.
That IS a separable board attached to an aluminium case yes? On which case peripheral works, after removing the metal.
PostPosted: Sat Mar 17, 2018 11:31 pm
i took a box cutter to the edge of the board, there was a clear plastic cover I peeled up. The black part is like some sorta decal.
PostPosted: Sat Mar 17, 2018 11:48 pm
Going with peripheral here for the same qualification as a floppy drive board.
