It is currently Tue Mar 17, 2026 6:59 am
 Post subject: Recycle or try to test?
PostPosted: Sat Mar 24, 2018 4:30 pm
Along with 34 computers and or servers that I took apart I also acquired some components that appear to be unused. Some aren't in packages though. I'm seeking some help to determine if the ones pictured here should just be turned in or if it may be worth testing them for service. Sorry if a question like that shouldn't be asked when trying to identify boards and other components.
PostPosted: Sat Mar 24, 2018 6:10 pm
If you can post the model numbers off those two boards I can run a search on them and see if any are or have sold in the last few years.
Hard drives I tend to believe are more trouble than they are worth as a “working” device sale. I don’t sell most drives at all unless it’s true IDE/HL or SCSI/SAS. Anything else the price doesn’t justify the headache of a doa.
If you do sell it as a working drive make sure you insure it. That way if mr post man drops it on his route or whatever you aren’t out the sale completely.
PostPosted: Sat Mar 24, 2018 6:46 pm
Hi I'm sorry I forgot to say it's the front and back of one board and that I don't know which one the model number is. The bag it was in has a part number on its label but I didn't get any results for parts. I think it's just recycle.
That makes sense on the HDs though. I'll go through them to see if any seem worth the trouble.
PostPosted: Sat Mar 24, 2018 7:05 pm
Wow, that’s an extensive rack board then. You’re at telco for that one.
If you’re not already set up for testing and repairing servers it’s probably not going to be reasonable to try to test these. They require proprietary power supplies that don’t usually match up to off the shelf atx/btx units. So you need to actually look up the manual and make sure the power headers match the wires on the supply or you can quickly fry the board.
The ram on the other hand has some value even untested.
Whoa, I literally have absolutely nothing on the numbers on that sticker. Sorry. Best guess is a custom design for that specific medical group or hospital
PostPosted: Sat Mar 24, 2018 7:14 pm
Okay so see if the board will fly in the telco pile and keep it's RAM separate from the rest?
PostPosted: Sat Mar 24, 2018 11:21 pm
The board is definitely telco. You’ll need to remove that canister battery first though.
PostPosted: Sun Mar 25, 2018 8:57 am
Thank you and I always double check for the different types of batteries.
