It is currently Fri Nov 06, 2026 5:46 pm
PostPosted: Wed Nov 29, 2017 5:58 pm
What can I remove for the board without it messing with the prices
PostPosted: Wed Nov 29, 2017 8:56 pm
Batteries, heat sinks, and extraneous metal. :p
If you pull things off like ic chips, pins, and such you will run the risk of downgrades rather quickly... I would avoid removing most anything soldered to the board. They are okay with removing CPU's and IC's that are in sockets as they have their own classifications.
PostPosted: Wed Nov 29, 2017 9:03 pm
If pull things off like ic chips, pins, and such you will run the risk of downgrades were quickly... I would avoid removing most anything soldered to the board. They are okay with removing CPU's and IC's that are in sockets as they have their own classifications.
PostPosted: Wed Apr 18, 2018 6:34 pm
Is it ok to leave the heat sinks on the boards?
PostPosted: Wed Apr 18, 2018 9:35 pm
See the other post today on this.
