It is currently Wed Aug 05, 2026 9:12 pm
 Post subject: Old Boards
PostPosted: Fri May 18, 2018 10:57 am
They came off from some old servers
 Post subject: Re: Old Boards
PostPosted: Sat May 19, 2018 7:45 am
I’m not grading your boards at all but two things here you need to do with first board to the left. Remove the small battery and also remove the RAM that is attached to it for a better pay out on that RAM.
PostPosted: Sat May 19, 2018 4:13 pm
Most of these design should fall into small socket motherboard.
Ram slot, processor socket, internal expansion, external expansion, and controllers and bridge chips.
As noted above please remove the battery and the ram is worth more loose.
Also, these are commonly screwed or riveted into a carriage tray. All base metal including trays would need to be removed.
PostPosted: Fri May 25, 2018 2:56 am
I'm not sure if you intend to sell them whole or part them out to some degree, but your board on the left has a nice row of tantalum processors, the little yellow rectangular guys. I stack these up for a while and then sell them on eBay for a good bit. It takes quite a good bit of them to reach a sellable quantity though. Cool boards!
PostPosted: Fri May 25, 2018 9:26 am
Do keep in mind once you start pulling things off Boardsort downgrades materials quickly
