It is currently Wed Aug 05, 2026 3:02 pm
 Post subject: Can I cut the fingers?
PostPosted: Fri May 25, 2018 10:17 am
Can I cut the fingers and still get telco?
PostPosted: Sun May 27, 2018 10:15 pm
The two green ones.
IF you leave all the ICs in their sockets AND also snip the clips off, yes fingers can come of and boards will remain in telco class.
The other one: this is a gold finger card with the ICs left in. Remove the ICs and (probably) be at peripheral.
Cut the fingers and leave the ICs in definitely peripheral.
So the math you need to do (hint use the green board fingers) is if the gold finger rate is worth MORE than the loss of telco; or, does the finger rate pass the difference in class loss.
PostPosted: Mon May 28, 2018 11:28 am
OK thank you!
