It is currently Thu Oct 29, 2026 12:39 pm
PostPosted: Fri Aug 01, 2014 7:48 pm
If by some chance I got some scrap computers from from schools, businesses, local governments, etc. and they want certificates to prove their individual hard drives were securely disposed of would boardsort issue cod?
PostPosted: Fri Aug 01, 2014 7:51 pm
Because many places want to know their information is disposed of without being breached. I have a local metal refinery that will issue cod for each hard drive. But they pay lower than boardsort and charge a fee for the certificates.
PostPosted: Fri Aug 01, 2014 8:14 pm
My suggestion would be to offer the destruction service yourself if you are able to comply with their requirements for destroying drives. I would perform a three-pass DOD wipe on the drives, then once the drives are wiped, disassemble them. Many places that destroy drives often put drives in a hydraulic press that exerts a ton (literally) of pressure on the drive, shattering the platters in the process. If you can't comply with the requirements being proposed, then I would ask boardsort directly via a private message or phone call to see if he can provide the service and how much he would charge to issue the certificate.
PostPosted: Fri Aug 01, 2014 11:11 pm
I would drill a couple of 3/8" holes clear through platter(s) and casing. They also make great flying targets. Their rectangular shape causes some serious wobble.
PostPosted: Fri Aug 01, 2014 11:25 pm
Ditto, if they are newer computers, they will most likely have a tool-less case and tool-less hard drive removal and you can destroy the HDD's right in front of them, but since they want a CoD, that probably won't work for them, but it is an idea you can bring up to them.
PostPosted: Sat Aug 02, 2014 7:18 am
I haven't ran into this issue yet but just wanted to know.
