It is currently Sun Sep 20, 2026 6:08 am
PostPosted: Wed Feb 26, 2014 5:24 pm
Currently you list HDD logical boards at $10/lb, does that include laptop HDD boards as well?
PostPosted: Thu Feb 27, 2014 10:31 pm
they've always taken laptop drive boards for me :)
PostPosted: Thu Feb 27, 2014 10:56 pm
I would imagine they would go at the same rate as desktop hdd logic boards. Given the size, you would need more laptop hdd boards to make a pound. You should be able to mix the two types together when sorting.
PostPosted: Fri Feb 28, 2014 8:16 am
Absolutely! We will buy them the same as full size HD boards.
Even though they do not weigh much, they are a lot easier to remove. The peel right off with little to no effort when you use the technique I described in this post:
Easy Hard Drive Sales
Good luck!
