It is currently Mon Jul 27, 2026 1:29 pm
PostPosted: Mon Feb 24, 2014 4:38 pm
Will you take them or do you buy them?
PostPosted: Mon Feb 24, 2014 5:44 pm
No, unfortunately we do not take those.
PostPosted: Mon Feb 24, 2014 8:29 pm
If you know how to safely discharge the picture tube, you can take the CRT apart and recover the following things:
* degaussing cable (#2 copper wrapped in electrical tape)
* yoke (#2 copper wrapped around a ferrous core)
* mainboard (aluminum heatsinks and transformers/cbms)
When done, reassemble the CRT and dispose per your local environmental laws.
PostPosted: Tue Feb 25, 2014 12:19 pm
If you don't have too many CRT's remove the copper and mainboard, then assemble them so they look like they work. Then take em to Goodwill. They will send them the a computer recycler and will be properly delt with without costing you or Goodwill anything. I just take the Aluminum and copper off and take 4-5 a week to each goodwill around me.
PostPosted: Fri Feb 28, 2014 1:34 pm
What is a cbms?
PostPosted: Fri Feb 28, 2014 2:07 pm
CBM = copper bearing motor. This includes pretty much any transformer or electric motor where you have copper wrapped around a ferrous core.
PostPosted: Sat Mar 01, 2014 10:16 pm
Also check with your local (city/county) dump to see if they recycle the TVs and such. Our county dump collects the TVs and ships them off for processing by prisoners at a specialized recycling facility located behind the fence of a federal prison. Since they recycle 100% of everything they get, it doesn't matter to them that all of the good stuffs (as far as I'm concerned) is already gone.
