 Post subject: GOLD FINGER CARD
PostPosted: Thu Aug 28, 2014 12:40 pm
Hi Moderators.
Do I need to remove the aluminum frame around the cpu chip on the card?
Thanks
 Post subject: Re: GOLD FINGER CARD
PostPosted: Thu Aug 28, 2014 1:57 pm
looks like the aluminum is riveted on. Would it be possible to post a macro of the GPU chip looking at it from one side? If there's a gap between the aluminum and the card itself, a small enough flat head screwdriver with gentle force should loosen the rivets to pop them off.
PostPosted: Thu Aug 28, 2014 2:12 pm
There are screws on the back. I rather not do the labor but I will remove the frame before sending.
Thanks for answering my question.
PostPosted: Thu Aug 28, 2014 9:45 pm
If screwed on, just remove the screws and it will simply fall off. Place the frame with your aluminum.
