It is currently Tue Mar 17, 2026 4:28 am
 Post subject: more pics
PostPosted: Sat Mar 01, 2014 3:42 pm
here are some pics
 Post subject: Re: more pics
PostPosted: Sat Mar 01, 2014 5:47 pm
Guessing by the photo of the CPU chip, it's probably a Socket 478 P4 or Celeron. Another photo showing the top of the chip would be helpful, but I'm willing to bet it's green fiber with a metal top.
The second board appears to be a power inverter board from a laptop or flat panel monitor and would likely go as mid-grade.
The last one appears to be mid-grade, but could be peripheral if the fingers on it have gold on them or there's more IC chips or gold pins on the other side.
PostPosted: Sun Mar 02, 2014 11:03 am
the fingers are gold
PostPosted: Sun Mar 02, 2014 7:40 pm
i found out what the cpu is so no need for identification on it thank you
PostPosted: Mon Mar 03, 2014 12:02 pm
As kgryczan had mentioned, the CPU will be either a Green/Brown Fiber with Metal or a P4/Green Fiber NO Metal, depending of course if there is a metal top on the other side. Must see that side to be certain.
The other boards can all be sold as Peripheral Grade at $1.40 per pound currently.
