PostPosted: Sun Nov 25, 2018 9:48 am
Is this one ok as is, or should the huge plastic connectors come off then clip the flat "pins"?
I keep forgetting to post the photos in reverse order. First photo above shows the large flat gold flashed connector with the plastic removed. Second is end view of terminals.
bottom photo is the board. about 3 inches wide and a foot long, with not much on it other than the capacitors.
PostPosted: Sun Nov 25, 2018 4:56 pm
As is it’s peripheral. Any cutting is going to lesson the grade. I can’t tell if the pins will make up for midgrade but I doubt it.
Leave this one be.
