It is currently Sun Sep 20, 2026 10:29 pm
 Post subject: Yellow IC?
PostPosted: Tue Nov 20, 2018 8:25 pm
I am new to this type of scrapping. Two questions is three legs on each side considered a IC chip? Plus I have a card with yellow chips
 Post subject: Re: Yellow IC?
PostPosted: Mon Nov 26, 2018 5:47 pm
The single inline pin packages (SIP) are not ICs. They are resistors, capacitors, oscillators, etc etc. ICs will always have 5 or more pins in a SIP package.
The yellow dual inline package (DIP). Are also not ICs. In this case you have a Bournemouth resistor package.
PostPosted: Mon Nov 26, 2018 8:15 pm
Ok I was unsure if 6 pins for a ic meant per side or total. So Boardsort will not buy either item then?
PostPosted: Mon Nov 26, 2018 9:36 pm
They can be left on boards without issue, but they do not buy for them separately.
