PostPosted: Tue Sep 23, 2014 6:36 am
Price?
PostPosted: Tue Sep 23, 2014 10:05 am
Gold tip connector ends at 75 cents. Make sure they are gold plated.
PostPosted: Thu Sep 25, 2014 10:37 am
Thank you
some help with these boards
PostPosted: Fri Sep 26, 2014 2:29 am
Telecom?
PostPosted: Fri Sep 26, 2014 1:19 pm
For the second picture I would give it Peripheral.
For the little boards in the third picture I would give it Peripheral as well except the brown board is a low grade at 0.16 per pound. Remove the ic chip from the brown board so you get the ic chip for $4.10 per pound. You may want to do the same with the other little board to maximize your return if they don't get graded telecom by the forum moderators.
The fourth picture I would grade that on at Peripheral like the other ones.
