It is currently Tue Oct 27, 2026 10:07 pm
 Post subject: Telecom?
PostPosted: Fri Sep 26, 2014 3:22 pm
Now I'm positive these are telecom, am I right? All ics are on top, none under.
 Post subject: Re: Telecom?
PostPosted: Fri Sep 26, 2014 3:36 pm
The board on top appears to be telecom. The one on the bottom is more in line with peripheral grade given that there are three empty spaces to the right where if they were populated with large ICs or flatpacks, it would get a telecom upgrade.
PostPosted: Fri Sep 26, 2014 8:15 pm
Well I could just go ahead and cut that off correct?
PostPosted: Sun Sep 28, 2014 7:54 am
I believe you can, but it might not do anything to upgrade the board, and you will lose weight and profitability as you have a peripheral grade and a mid grade board.
