PostPosted: Mon Nov 17, 2014 12:36 am
I've looked through many posts, have a pretty good idea what I have here, just wanted confirmation, Thanks!
File comment: Pulled from a Cisco router. Unfortunately I believe this is peripheral...
File comment: Pulled from a Cisco Switch. Unfortunately I believe this is peripheral...
File comment: Telecom? Should I remove that little board?
File comment: Telecom? This one is questionable
PostPosted: Mon Nov 17, 2014 10:45 am
Second picture is peripheral foe sure. Third picture is telecom. No need to remove the little board since that board is telecom as well. Fourth picture you may get telecom or multiple socket board depending of the socket size
PostPosted: Mon Nov 17, 2014 12:04 pm
No comment on the 5th one eh... That could go as multi-socket too I guess. At this point it looks like I am going to have a fair amount of peripheral. Hope to find a local buyer for the peripheral and small metal socket MB. Not worth shipping...
PostPosted: Mon Nov 17, 2014 9:49 pm
A lot of your enterprise grade router and switch boards fall into the telecom category due to the number of flatpacks present and the existence of tantalum capacitors. Looking at your cisco boards, those will pass as telecom. Your fifth photo appears to be telecom grade.
PostPosted: Wed Nov 19, 2014 2:45 am
Once it was determined these were peripheral I removed the flat packs and degraded the boards.... Oh well, Live and learn.
Thanks for the info.
