 Post subject: Boards- What kind?
PostPosted: Sat Nov 22, 2014 6:56 pm
I have these boards that I don't know what they would go under. Any thoughts?
BTW- I have a bunch to identify, so maybe I can keep adding to this and taking some out...I'll try not to post to much to upset everyone.
 Post subject: Re: Boards- What kind?
PostPosted: Sun Nov 23, 2014 11:30 am
They are all peripherals except for # 5. That one I'd put it with my mid grade unless there is gold plating at the bottom of the board.
PostPosted: Mon Nov 24, 2014 2:43 pm
Looks like #5 came from a laptop display panel or flat screen monitor. Those will go as peripheral because there are a few ICs on them and you also have the gold plating where the screen connects.
PostPosted: Mon Nov 24, 2014 11:36 pm
Concerning #5. It appears this particular board has gold plating in a continous strip where it connects to the screen. If you had that same board but gold plating only at the points of contact (denoted by the mylar remnants), would it be the same grade?
PostPosted: Tue Nov 25, 2014 1:44 pm
It would be. I've had laptop display panel boards and LCD boards graded by boardsort and peripheral is what they told me they were. The fact that you have that strip of gold plating is making up for the fact that there's very little IC population to give it anything higher such as finger card.
PostPosted: Tue Nov 25, 2014 2:06 pm
Thanks for the info. Yeah I think I took it out of a flat screen. Its superlight weight, but I'd rather sell it then trash it :)
