It is currently Mon Jul 27, 2026 3:34 pm
PostPosted: Sat Dec 13, 2014 2:50 pm
Any tips on removing the board from the plastic case and aluminum heat sink?
PostPosted: Sun Dec 14, 2014 2:55 am
flat head screwdriver works really well. the plastic pops off quite easily. And once you break the plastic off, just use the screw driver to pry the flimsy brackets off the heatsink.
PostPosted: Sun Dec 14, 2014 8:41 pm
Doesn't pop off easily for me. Feels like I'm going to crack the green board. Maybe I'm prying in the wrong spot. I'll try to find a YouTube video of someone doing it.
PostPosted: Mon Dec 15, 2014 12:27 am
I've done a few dozen in the last couple of weeks. Each one gets easier. its more about getting underneath the plastic enough to pop the brackets and keep moving along until you get get some space for your fingers. then just rip the plastic off.
PostPosted: Sun Dec 28, 2014 8:37 pm
You are doing it the hard way :=)
At the top of the processor are 2 tabs. Push these in, hard. It is OK if they break off.
Remove any metal clip holding the 2 halves together.
At the edge, find the indent in the plastic. Insert a flat blade screwdriver, and twist.
Everything pops apart, takes less than 1 minute once you get proficient.
