It is currently Sat Aug 29, 2026 6:12 pm
 Post subject: Motorola computer
PostPosted: Tue Feb 05, 2019 1:45 pm
I have some of these want to make sure all gets in the right boxes
Thanks for the help
 Post subject: Re: Motorola computer
PostPosted: Tue Feb 05, 2019 2:02 pm
Oops one more
PostPosted: Tue Feb 05, 2019 3:13 pm
Telco
1)peripheral
2)small green socket
3)wire, cut the gold pin connector off
4)peripheral
5)peripheral
6)peripheral
7)green brown fibre
8)ram
9)telco
Hand photo additions
Telco, you can keep your hand. Boardsort doesn’t buy body parts
PostPosted: Tue Feb 05, 2019 3:16 pm
Sweet
PostPosted: Tue Feb 05, 2019 3:19 pm
No gold finger on the first and why would it not be so I can understand the difference
PostPosted: Tue Feb 05, 2019 3:22 pm
Or was you saying both in hand are telco 1 pic and added pic
PostPosted: Tue Feb 05, 2019 4:30 pm
Ohkay. Hands was a bad joke. Don’t cut off your and and mail it in. It’s not worth any money to them and will probably gross a few people out. And all. Bad joke
The gold finger card in the first post
This is a telecommunications class board. A class Including many telephone/networking controllers, PCMCIA and compact flash cards. Open deshelled flash memory like SD.
These cards are slightly more valuable than the gold finger class rate.
This one isn’t there but some of these have a ‘secret’ class called air card. And on extremely rare occasions can even make it to cell class.
The second post, I assumed it was the same chip.
If not the Epson card is telco and the other one is peripheral. That epson chip is a full fledged processor. The epoxy package instead of a ceramic one means the internal wire and etch matrix is more likely sliver, nickel, and copper; instead of the more valuable gold and nickel matrix found in ceramic ICs and many BGA chips.
PostPosted: Tue Feb 05, 2019 4:40 pm
Top most gfc telco card. Has a reduced implementation cisc processor. A bus signal processor. A usb (or ESB) controller, and a timing chip. Just on the pictured aide. Two gold socket ports for antenna connectors. No copper capacitors, no canister capacitors. All on an etched board vs tracing. Combined with the reduced sizing... jump to telco.
