 Post subject: QFNs and Leadless?
PostPosted: Tue Feb 26, 2019 4:03 am
Are QFNs and DFNs considered ICs to boardsort's standard?
 Post subject: Re: QFNs and Leadless?
PostPosted: Tue Feb 26, 2019 4:05 pm
Modern chips
as long as it doesn’t have a full fledged spreader yes, IC rate
With a heavy tungsten spreader it goes pinless
If it’s an old ceramic chip like the i286/80286, Motorola, MOS etc
For gold connectors post a picture
Everything else goes as IC
PostPosted: Wed Feb 27, 2019 12:06 pm
Thanks for the reply! Kinda confused on what you mean by spreader tho? As in a center pad(ground pad)?... Would you mind clarifying if these would be sellable. Obviously after accumulating much more thanks
PostPosted: Wed Feb 27, 2019 12:12 pm
Might be hard to see but #4 is dfn that has gold pads. Not sure if this would be a different category of ics.
File comment: #4
File comment: #3
File comment: #2 these I'm pretty sure are the basic standard? All Soics and and QFPs
PostPosted: Wed Feb 27, 2019 3:37 pm
Everything except 4 is standard IC chips.
#4 would be at Chris’s discretion as to where it would go: you can email him the photo.
By spreader I’m referring to a piece of metal, usually tungsten or tungsten plated copper,
About 1/8-1/16th of an inch thick that weighs more than the IC it’s attached to.
PostPosted: Thu Feb 28, 2019 1:01 am
Awesome! Much appreciated, ill keep qfns with gold contacts separate from now on.
And oh okay! I recognize those, so spreaders are the metal plate typically on larger BGAs and such?
PostPosted: Thu Feb 28, 2019 5:26 am
Typically yes. But on ultra condensed boards, eg embedded systems, they can be found on the tiniest of ICs.
I stole Chris’s photo for the example since I come across the micro minis so rarely I never thought to photo one.
