It is currently Sat Aug 01, 2026 2:04 pm
PostPosted: Wed Apr 10, 2019 9:04 am
Hello there,
I pulled about 50 units of the same tiny board from a set of Fujitzu document scanners. These aren't the flatbed kind though. They look like a small printer. I noticed it sort of looks like an ic chip because of the legs but it's not all solid black. It has a glass on top with what looks like more golden portions inside. The legs are in a gold color. Can you help me identify these?
Thanks,
Natalia
PostPosted: Thu Apr 11, 2019 2:01 am
Excellent!
Do you think I can remove the IC chip from the board and sell it separately as a gold legged IC chip?
Thank you again for all your help.
Natalia
PostPosted: Thu Apr 11, 2019 2:11 am
That’s the optical IC from a scanner. The board is peripheral
PostPosted: Fri Apr 12, 2019 2:49 pm
No you can’t remove it for a better price. I’ve tried. ;)
Too much glass to gold ratio.
PostPosted: Tue Apr 16, 2019 2:35 pm
Oh that's terrible news.... well I guess I learned something new today in regards to these IC chips.
Thanks again for your time.
Natalia
PostPosted: Wed Apr 17, 2019 11:15 am
Yep. The ones you can easily pop loose or already have removed you can cut the pins off.
I’ve done that too.
However this is a case where you’d be better off leaving them on.
