It is currently Fri Jul 31, 2026 11:51 pm
 Post subject: Some odd balls.
PostPosted: Mon Dec 31, 2018 4:06 pm
Not sure how to class these or even if boardsort buys them. Some are expensive on Ebay, but no way to test and waiting a year to sell, lol.
The plc board is an Alen Bradley. 10" x 6".
The Mitel is a telecom module. Do not see any gold contacts. 10" x 8".
DEC Alpha processor board. 13.5" x 5.5".
DEC Alpha cache module. Only gold contacts are where batteries connect. 12.5" x 7.75".
 Post subject: Re: Some odd balls.
PostPosted: Mon Dec 31, 2018 5:58 pm
Plc, given there’s no excess weight in these pressed film boards, it will clear peripheral rate.
Mitel will be peripheral
Dec processor remove the tray and heat sink for telco
Dec I’ve had success snapping these boards in half, just to the left (in the photo) of the copper tabs. Then you have a telco half and a piece of low quality plastic.
Use a rigid heavy box cutter or hunting knife to make a deep, straight score down the middle and you should get a clean snap.
PostPosted: Mon Dec 31, 2018 6:05 pm
Btw, remove the metal on the last board before you try to snap it. Lol
PostPosted: Mon Apr 29, 2019 5:02 pm
I forgot to thank you on these Lost, so Thank You! :)
PostPosted: Mon Apr 29, 2019 6:01 pm
i belive that varta box is a li-ion battery
PostPosted: Mon Apr 29, 2019 6:30 pm
Evil is lurking! Lol.
Granted this is long past discussion; but which photo are you looking at... I’m not seeing it.
PostPosted: Wed May 01, 2019 10:48 pm
^yeah finely aged post lol...
Code:
File comment: mitel 2
bottom left corner ...the photo is unclear but i have problems with removal of those before ..
PostPosted: Thu May 02, 2019 3:41 am
Wow. Totally missed it. Yes that is probably a battery.
