It is currently Sat Aug 01, 2026 2:31 am
 Post subject: Question
PostPosted: Fri May 03, 2019 1:38 am
What would this qualify for?
If I remove the gold plated finger part, what does that go for as being only one sided gold plated fingers?
If I remove the excess plastic to where I only keep the area where the gold dots are, what would that go for alone?
 Post subject: Re: Question
PostPosted: Fri May 03, 2019 2:04 am
Whole it’s mixed wire.
So trim the gold end off and put it in with your gold fingers.
The wire is still mixed wire.
PostPosted: Fri May 03, 2019 2:06 am
If you trim the contact ‘dozs’ Extremely close you can place the dot strips in gold finger as well. That’s what I normally do.
