It is currently Thu Sep 24, 2026 11:45 pm
PostPosted: Thu Mar 28, 2019 7:16 pm
What should I do with this piece..it came out of some kind of server...the pins are in heavy ferrite
PostPosted: Thu Mar 28, 2019 11:08 pm
Looks like a relay board.
You can leave them in if they're snug, and get a gold pin connector rate.
Or you can wiggle and tug them out for clean gold pin quotes.
PostPosted: Tue Apr 30, 2019 8:05 am
Are those pins fused with something on the other side usually on these types of boards?
You'll quickly realize how great these fat burners for men really are if you give them a shot.
PostPosted: Wed May 01, 2019 2:35 am
Sometimes. Sometimes they’re soldered into the bottom. Sometimes they have tiny little clips that slide into ridges, like a spring but based on friction instead.
Usually they’re slightly larger than the hole and are just hammered in.
PostPosted: Sun May 26, 2019 5:12 pm
They are not coming out easy..how but smash ferrite and pick out pins?
PostPosted: Sun May 26, 2019 10:45 pm
Sounds like a plan. I didn’t think of that. :(
