PostPosted: Thu Jan 08, 2015 11:56 am
Ok, So I've sorted the obvious stuff in my stash. I have these items that I need to sort, weigh, pack and ship. Hoping I can get all this stuff in one box!
So, here goes... there is quite a bit... If anything can be upgraded by removing a bracket, let me know. Might be worth a difference between finger card vs telecom in a couple cases...
File comment: #1-DLP board top
File comment: #1-DLP board bottom
File comment: #2-Mac motherboard. Had a 68040 CPU
File comment: #3
File comment: #4
File comment: #5
File comment: #6-tops
File comment: #6-bottoms
File comment: #7-tops
File comment: #7-bottoms
File comment: #8-tops
File comment: #8-bottoms
File comment: #9-tops
File comment: #9-bottoms
File comment: #10
File comment: #11
File comment: #12
File comment: #13
File comment: #14
File comment: #15
File comment: #16-top
File comment: #16-bottom
File comment: #17 Could this go as telecom?
File comment: #18 Could this go as telecom?
Hoarder turned scrapper.
PostPosted: Thu Jan 08, 2015 1:47 pm
Here are my two senses....BTW, you dont need to remove anything as far as I can see. Wait for a final grading from the forum moderators though.
Pic #1 It looks like a laptop motherboard but in your description you wrote DLP. I think it could go for Telecom based on the ic presence.
Pic #3. If the socket lenght is more than 1.75 inches then large socket motherboard. I think Mac motherboards go for Large Socket MB. It could go for Telecom.
Pic #4. Peripheral
Pic#5. Gold finger card
Pic #6. Telecom
Pic #7 Top board is telecom and the bottom board could be large socket motherbaord or telecom
Pic #9, 11, 13 Peripheral
Pic #15 Peripheral or best case Telecom
Pic #16 Peripheral or best case Telecom
Pic #17 Peripheral or best case Telecom
Pic #18 Peripheral
Pic #19 and 20 Gold finger card. It could go as Telecom in best case scenario
Pic #21 Gold finger Card
Pic # 23 and 24 Telecom. At worst Gold Finger Card
PostPosted: Thu Jan 08, 2015 9:19 pm
Is it ok to give my best guess and just stick a label on the items that are questionable? All my other items are easy stuff. CPUs, RAM, motherboards, basic gold finger cards, etc.
Tony
PostPosted: Fri Jan 09, 2015 2:31 pm
That's a very viable way to organize your shipment. If you are driving to the facility you can just put those board in question in a separate box and you will get the proper grade in person. If shipping you can wait for the moderators to give you their advise to avoid boardsort adjusting your shipment. This way you dont send lower grade boards that the shipping isnt worth it.
PostPosted: Fri Jan 09, 2015 4:16 pm
Shipping. The waiting is the hardest part. :-) I did send Chris an e-mail to review my post. Hoping to get this on the way Monday or so. Otherwise, I might just hold these back and send what I do have identified properly. Once I get in more high value/weight stuff, I can throw those in. Luckily, I'm in Ohio, so shipping isn't too hateful.
Tony
PostPosted: Sat Jan 10, 2015 12:54 am
On those rate as telcom , remove the gold fingers first as close as possible this should not degrade if telcom. as it is the chips they are paying for not the fingers. otherwise they may only give the finger board rate.
I have had this happen in the past only to learn later with sales to other buyers.
PostPosted: Thu Jan 22, 2015 5:45 pm
I got answers from Chris via e-mail on all of these. I'll follow up here so everyone knows how they ranked. A couple surprises in there, actually.
Tony
