 Post subject: PLC or ?
PostPosted: Sat Jan 10, 2015 12:54 am
Is this considered a PLC? Just trying to figure out how to get the most for it, or its components.
 Post subject: Re: PLC or ?
PostPosted: Sat Jan 10, 2015 11:12 pm
Scrap it and post pictures of the boards to see the grade.
PostPosted: Mon Jan 12, 2015 10:41 pm
Here is whats inside.
PostPosted: Tue Jan 13, 2015 2:54 am
In the first picture the board is very low key that it may low or mid grade. In the second picture it looks like you have some peripheral boards. Now the board to the right standing up (it has a battery attached) has some good ic population that it may be a Telecom board. Remove it and take a shot alone to see it better. Hopefully the forum moderators can properly identify it for you.
PostPosted: Tue Jan 13, 2015 10:02 am
In the first photo, the board behind the LCD appears to be mid grade. See if you can remove the backing off the board that is behind the keypad. Sometimes, those boards have gold plating on the keypad contacts, or there's a mylar that contains silver.
On the bottom, it appears that all the boards there are peripheral, but the board that is laying flat in the photo is actually two boards stacked on top of each other and held in place with screws. Separate the two boards and post photos of them to get the most accurate grading.
